![]() | Home > Technical > Cam belts. |
Yes the front belt will cause the clash.
harrij Member Since: 30 Jan 2018 Location: Nantwich Posts: 12 ![]() ![]() ![]() |
Cheers Andy, what think you of 130K on same belt, don't think I would chance it? Regs JH. |
I'd be more concerned about the oil pump... |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 590 ![]() ![]() |
Metal ware like Mike has said will be the first to fail before a belt does |
I have my belts change coming up on my 2012 3.0 sdv6. Is the oil pump an issue there ? What else is worth changing out and replacing at the same time ? |
The oil pump issue was on the 2.7TDV6 from around 2006-2007 (not sure of the exact time period). The problem with the SDV6 appears to be access to do the job - see https://www.disco3.co.uk/forum/sdv6-timing...54-15.html 2012 SDV6 - it's missing a couple of cylinders
No, just belts ![]() And its not a body off job either ![]() |
Cheers Mikey. That's a relief. |
That's good news! ![]() 2008 TDV8 - it was a labour of love and is much missed |
My previous employers still lift the body to replace the belts, and are more expensive than the main dealer |
Theiving etceteras Mikey.
