Home > Technical > Cam belts.
harrij
United Kingdom 2007 Range Rover Sport TDV6 SE Java Black
Cam belts.
Q, if a cam belt lets go (breaks) on a 2.7 engine will the pistons contact the valves? I have just seen a cam belt that has been in a 2.7 for over 130K and it showed V little wear, the charge for renewal was £375 including the belt I am told. Bargain?
Regs All JH
Post #554646 Fri Apr 20 2018 10:40am
Yes the front belt will cause the clash.
The rear fuel belt isn't so much of a problem
Sounds a good price
On a 2007 you need to replace the oil pump too else you will be Big Cry
Costs about £120 from advanced factors plus a bit of labour + bolt/seal.
The belt tensioner is on the oil pump and they frequently break off after belt replacement.
Post #554650 Fri Apr 20 2018 11:28am
harrij
Cheers Andy, what think you of 130K on same belt, don't think I would chance it? Regs JH.
Post #554653 Fri Apr 20 2018 11:56am
Disco_Mikey
I'd be more concerned about the oil pump...
Post #554654 Fri Apr 20 2018 12:56pm
Red Arrow
Metal ware like Mike has said will be the first to fail before a belt does
Post #554656 Fri Apr 20 2018 2:09pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
I have my belts change coming up on my 2012 3.0 sdv6. Is the oil pump an issue there ? What else is worth changing out and replacing at the same time ?
Post #554826 Mon Apr 23 2018 11:46am
The oil pump issue was on the 2.7TDV6 from around 2006-2007 (not sure of the exact time period). The problem with the SDV6 appears to be access to do the job - see https://www.disco3.co.uk/forum/sdv6-timing...54-15.html 2012 SDV6 - it's missing a couple of cylinders
Post #554829 Mon Apr 23 2018 12:25pm
Disco_Mikey
No, just belts Thumbs Up
And its not a body off job either Thumbs Up
Post #554832 Mon Apr 23 2018 12:45pm
Father Jack
Cheers Mikey. That's a relief.
Post #554838 Mon Apr 23 2018 1:36pm
That's good news! Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #554840 Mon Apr 23 2018 1:49pm
Disco_Mikey
My previous employers still lift the body to replace the belts, and are more expensive than the main dealer Rolling with laughter
Post #554848 Mon Apr 23 2018 2:18pm
Father Jack
Theiving etceteras Mikey.
My local indy I use in the west mids (Terry at Ultimate 4x4 in Dudley, recommended) confirmed can do without taking body off when I asked him about this a couple of months back.
Post #554863 Mon Apr 23 2018 4:37pm
