![]() | Home > Maintenance & Modifications > Sump Guard Removal |
I feel your pain; having recently struggled with one of the bolts on my undertray.
GARYF123 Member Since: 03 Jan 2015 Location: leeds Posts: 143 ![]() ![]() ![]() |
Hi, I had same problem last week! I ended up using a angle grinder with thin metal cutting disc and cut slot into bolt head. I cut full depth which allowed me to knock the bolt round. I could also reuse the butchered bolts to temporarily hold the tray until I purchase replacements. I don't think you will damage the welded captive nuts as I was using a impact wrench, hammering and grinding and they didn't budge!
slinger Member Since: 11 Sep 2016 Location: Loughborough, Leicestershire Posts: 19 ![]() ![]() |
Thanks for the replies guys. Seems this is yet another design feature from Land Rover. I managed to get the last three bolts out with an air chisel and using a hammer and chisel. Replacement Land Rover bolts all round would have been over £30 but I got a full set of flanged bolts and bought nuts, springs and washers for all for only £3. I didn't need nuts on all but with not knowing what I would end up with and for the cost I didn't want to half do the job. Copious amounts of copper grease and it is all back together after changing the oil.
It makes one wonder how careful the servicing has been if the bolts were so badly seized / corroded. Taking the sump plates off would be part of an oil change... 2012 SDV6 - it's missing a couple of cylinders
WesleyThompson Member Since: 01 Apr 2018 Location: Cheshunt Posts: 2 ![]() ![]() ![]() |
Same happened to me today I had to call it a day and leave the car on the ramps. Left the bolts with penetrating fluid on to soak through the night |
Morgi27 Member Since: 31 Jan 2015 Location: Birmingham Posts: 88 ![]() ![]() ![]() |
If it's supposed to have had oil change 10 months ago carnt see how they would have rusted fast!
Dealers don't always drain the oil these day's via the sump plug, they use a oil extraction pump to remove the oil from the engine using the built in tube, although I don't know if a 58 plate vehicle has this facility, which could explain why the guard is not always removed.
