![]() | Home > General (L494) > Another engine failure |
thomas brown Member Since: 29 Mar 2016 Location: Norwich Posts: 559 ![]() ![]() ![]() |
You can't beat a good old Td5 discovery 2. I Still have one in my garage as my baby can't sell her. We'll as long as the oil pump drive bolt is tight ! He, he. Then there pretty solid.
I read in this months Land Rover Monthly that the TD5 was probably their best engine....
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
We do have a lack of hard information here.
It would not be so bad if JLR let you buy an engine at a reasonable discounted price, however as stated, a new engine installation is often worth more than the vehicle. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Be interesting if we knew when people leave the Land Rover Marque, what they moved to. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
362bkr Member Since: 06 Dec 2013 Location: devon Posts: 856 ![]() ![]() ![]() |
Well given this situation and the fact that I am due to renew mine it’s either get the v8 diesel next or move brand but there is nothing out there anywhere near the same ................ is there ? |
james5599 Member Since: 14 Jun 2009 Location: london Posts: 325 ![]() ![]() |
I like the X5M / cayenne turbo . 2019 Svr and 2019 R35 GTR |
I have been tempted by an X3. I know BMW, |
Apparently in south Africa its about 1.3% of sales i just read which does not sound a lot but it still sounds like an awful lot of money and i agree land rover should stump up a better than 20% contribution if its all been serviced and the recommended oils used |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1179 ![]() ![]() ![]() |
that's LR's official PR horse manure - the figure is much, much higher than this.
WOW NOW THATS A LOT |
# Interesting that the source you quote is talking about pre 2012 engines only: “The issue affects only 1.3 percent of Land Rover engines sold in South Africa over the past 10 years,” she said. “Changes have been made at a production level and all new engines manufactured since 2012 use a new bearing design" So what is happening with m roe recent engines? Is it just a "normal" failure rate? Same as any other marque suffers from? (All mechanical things break to some degree) MY2016 HSE D SDV6 - gone due to fuel dilution problems. By the age of 50 you have the face you deserve - George Orwell. |
If changes have been made, the cranks shouldn’t be failing...
