Home > General (L494) > Another engine failure |
Been-and-dunit Member Since: 15 May 2016 Location: Burton on trent Posts: 145 |
I have sent LR a email about this issue,let's see if they reply . It's a bit worrying when you have a L494 with 7 months left with warranty |
Thu Feb 15 2018 8:42pm |
362bkr Member Since: 06 Dec 2013 Location: devon Posts: 856 |
You will receive a reply saying they will deal with every claim in a case by case basis bla bla bla ......... |
Thu Feb 15 2018 8:56pm |
In other words F--- O-- will see if they reply let you know |
Thu Feb 15 2018 8:59pm |
This might be ALL their engines, only crankshaft failure and not the just V6 diesels so the proportion of the V6 diesel 'might' be much higher! |
Fri Feb 16 2018 9:35am |
KieRRSAB Member Since: 04 Apr 2015 Location: North East Posts: 2 |
March 2015 AB v6 diesel - 80,000 miles and engine fails, fortunately covered under manufacturer’s warranty. Main dealer has been excellent providing a courtesy RRS, however, they have been unable to explain what went wrong as entire engine unit has to be returned to JLR. Approvals for new engine and engine harness authorised very swiftly by JLR - should get car back in next 7 days, unfortunately I only have just over 1 month remaining on warranty. |
Fri Feb 16 2018 9:57pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
A new engine from LR will come with two years of warranty anyway, irrespective of any vehicle warranty. 2012 SDV6 - it's missing a couple of cylinders
Sat Feb 17 2018 12:24am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
It is actually only warranted until the end of the original warrany period...
Sat Feb 17 2018 7:22am |
Really? All LR parts fitted by a LR dealer are covered by a two year warranty of their own. Why should an entire engine be any different? 2012 SDV6 - it's missing a couple of cylinders
Sat Feb 17 2018 10:47am |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 |
15k for a new engine i would expect at least a two year warranty from when fitted. SVR 2018 in Santorini Black. |
Sat Feb 17 2018 11:13am |
Is it that if it’s paid for by the warranty then it’s only guaranteed till the end of the warranty ? |
Sat Feb 17 2018 11:14am |
Correct ☝️ |
Sat Feb 17 2018 12:50pm |
The bill with the engine harness is closer to £30k and the warranty expires in 1 month. |
Sat Feb 17 2018 1:08pm |
Mikey, can you tell us what you would charge to source and fit a used engine, (typical cost) This info may be of use to quite a lot of forum members. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Sat Feb 17 2018 1:18pm |
Never fitted a used 3.0, due to them themselves so often...
Sat Feb 17 2018 8:01pm |
