Home > Maintenance & Modifications > Injector trouble |
Sharpy1980 Member Since: 24 Sep 2016 Location: Kent Posts: 98 |
If it’s the same as the tdv8 then the different part no’s only dictates what angle the wiring connector points on top of the injector but there is usually enough slack in the wiring either way but it just isn’t as neat and you have to be careful of chafing Clickadeeclick |
Sun Feb 04 2018 8:45pm |
Rangeysean Member Since: 04 Feb 2018 Location: Plymouth Posts: 5 |
Hey Sharpy, thanks for the speedy response pal. Yea makes sense to be honest, as there are both on there already. Is there anyway of finding out (without going through RR) to find out which one is the correct variant? |
Sun Feb 04 2018 8:50pm |
Your engine will have both it just depends on which injector you change will depend on which one you need but as I said the wiring should reach,
Sun Feb 04 2018 11:22pm |
Sun Feb 04 2018 11:32pm |
This is most helpful, thank you 😊
Mon Feb 05 2018 10:08pm |
Fully trained no but semi skilled yes, it really depends on what your comfortable with cleanliness is fairly important but apart from that you can’t really make anything worse, if you are methodical and know your way around a tool kit and are patient and can follow a manual then there is no reason not to give it a go, you will need a torque wrench that goes down low and it’s important to torque them down correctly, also make sure the old copper washers have come out on the old injectors and you replace those
Mon Feb 05 2018 10:21pm |
Here it is, everything you need to know thanks to discomikey
Mon Feb 05 2018 10:28pm |
Hey Sharpy
Sat Feb 17 2018 11:24am |
No worries glad you got it sorted Clickadeeclick |
Wed Feb 21 2018 5:39am |
