Home > Faults & Fixes > hand brake fault |
Codes need reading first that's the easiest way to get help |
Tue Sep 26 2017 6:35pm |
blueiceplus Member Since: 21 Feb 2014 Location: wigan Posts: 66 |
Thanks |
Tue Sep 26 2017 6:48pm |
mncc Member Since: 26 Jan 2018 Location: essex Posts: 1 |
probably a bit late just joined but my rrs had same problem turned out to be battery on way out go to you tube self diagnostic code if 12.1 or below volts could be |
Fri Jan 26 2018 8:28pm |
Mr Bid Member Since: 01 Jan 2018 Location: Scotland Posts: 1 |
Thanks, You have confirmed my suspicions... 2008 Model with genuine LR battery still, so probably about done!
Sun Jan 28 2018 11:17am |
