![]() | Home > Faults & Fixes > hand brake fault |
Codes need reading first that's the easiest way to get help |
blueiceplus Member Since: 21 Feb 2014 Location: wigan Posts: 66 ![]() ![]() ![]() |
Thanks |
mncc Member Since: 26 Jan 2018 Location: essex Posts: 1 ![]() ![]() ![]() |
probably a bit late just joined but my rrs had same problem turned out to be battery on way out go to you tube self diagnostic code if 12.1 or below volts could be |
Mr Bid Member Since: 01 Jan 2018 Location: Scotland Posts: 1 ![]() ![]() |
Thanks, You have confirmed my suspicions... 2008 Model with genuine LR battery still, so probably about done!
