Home > Faults & Fixes > hand brake fault
blueiceplus
United Kingdom 2008 Range Rover Sport TDV6 SE Cairns Blue
hand brake fault
would anyone know what the fault would be on my 2008 rrs when it comes up as parking brake fault all the dash light come on and the vehicle go's into limp mode. Crying or Very sad
Post #536486 Tue Sep 26 2017 5:54pm
geoffsnook
Codes need reading first that's the easiest way to get help Thumbs Up
Post #536496 Tue Sep 26 2017 6:35pm
blueiceplus
Thanks
Post #536499 Tue Sep 26 2017 6:48pm
mncc
England 2007 Range Rover Sport TDV8 HSE Java Black
probably a bit late just joined but my rrs had same problem turned out to be battery on way out go to you tube self diagnostic code if 12.1 or below volts could be Thumbs Up
Post #546852 Fri Jan 26 2018 8:28pm
Mr Bid
Thanks, You have confirmed my suspicions... 2008 Model with genuine LR battery still, so probably about done!
Just joined myself, and have the same issue...
A relay is also clicking under the glovebox, suspect it's the remainder of the alarm's efforts to sound?
I'm off to get another battery now so will update if fixed.
Post #546970 Sun Jan 28 2018 11:17am
