![]() | Home > General > Help please bottom front wishbone tdv8 |
If your doing it i would change the whole arms unless you have a ramp and all the tools they can be |
Call Advanced Factors in Southampton.
Tel02sport Member Since: 02 Jul 2017 Location: Surrey Posts: 14 ![]() ![]() |
I have access to a two and four poster ramp and press thanks for you advise I think I will bush it my car has only done 35000 miles so arms are in good condition so will fit bushes too my arms thanks again ๐๐๐ |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9053 ![]() ![]() ![]() |
The issue isn't the condition of the arms, it's whether you can get the bolts out. They usually seize in the bushes and the easiest option is to cut the arms off. If you're doing it yourself then time taken to free the bolts might be less of an issue. If paying someone else then it's usually cheaper to buy and fit new arms.
So new boots are poss needed to get the job done too ??? |
As said by RRSTDV8 it does not matter if the bolt donโt want to come out it wonโt trist me I know I have done it twice so new bolts can be needed also seen people cut the arms to get them out but if they come out ok then use super pro as they are softer than polly bushes and not so harsh |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4454 ![]() ![]() ![]() |
Superpro bushes are designed to be as compliant as OEM rubber bushes, while lasting much longer
Where can I buy super pro bushes ? |
I think advance factors sell them or try ebay have seen them on there |
Ok thanks Geoff great help |
