Home > General > Help please bottom front wishbone tdv8
Tel02sport
Hello could anyone help ??? I have a. Tdv8 2009 bottom front wishbone bushes worn I have been advised to change bushes for polly bushes (powerflex) rather than pay out for new complete wishbone has anyone done this and if so I'm looking for what's best todo ?
Post #545532 Thu Jan 11 2018 4:07pm
geoffsnook
If your doing it i would change the whole arms unless you have a ramp and all the tools they can be Censored to get off and out but its really up to you powerflex bushes will last longer. Or you can source a pair of knackered bottom arms from ebay and refurb them with the new bushes either normal or powerflex then they will be ready as soon as the old ones come out and may save you a bit on garage labour or your time Thumbs Up
Post #545544 Thu Jan 11 2018 7:45pm
DrRob
Call Advanced Factors in Southampton.
Site sponsor so discount Thumbs Up Visitor from fullfatrr.com
Post #545554 Thu Jan 11 2018 8:49pm
Tel02sport
I have access to a two and four poster ramp and press thanks for you advise I think I will bush it my car has only done 35000 miles so arms are in good condition so will fit bushes too my arms thanks again ๐Ÿ‘๐Ÿ‘๐Ÿ‘
Post #545559 Thu Jan 11 2018 9:38pm
The issue isn't the condition of the arms, it's whether you can get the bolts out. They usually seize in the bushes and the easiest option is to cut the arms off. If you're doing it yourself then time taken to free the bolts might be less of an issue. If paying someone else then it's usually cheaper to buy and fit new arms.
Probably worth doing the bottom ball joint too. 2012 SDV6 - it's missing a couple of cylinders
Post #545566 Thu Jan 11 2018 9:47pm
Tel02sport
So new boots are poss needed to get the job done too ???
Post #545568 Thu Jan 11 2018 10:02pm
geoffsnook
As said by RRSTDV8 it does not matter if the bolt donโ€™t want to come out it wonโ€™t trist me I know I have done it twice so new bolts can be needed also seen people cut the arms to get them out but if they come out ok then use super pro as they are softer than polly bushes and not so harsh Thumbs Up
Post #545569 Thu Jan 11 2018 10:08pm
Disco_Mikey
Superpro bushes are designed to be as compliant as OEM rubber bushes, while lasting much longer
Polybushes are very harsh on the road
Post #545607 Fri Jan 12 2018 8:06am
Tel02sport
Where can I buy super pro bushes ?
Post #545976 Mon Jan 15 2018 4:20pm
geoffsnook
I think advance factors sell them or try ebay have seen them on there Thumbs Up
Post #545980 Mon Jan 15 2018 4:44pm
Tel02sport
Ok thanks Geoff great help
Post #545985 Mon Jan 15 2018 5:45pm
