Home > Technical > Gearbox fault
Welshian
Wales
Gearbox fault
My 2013 L494 has started to hold in 7th gear, if I then go to command shift and do it manually it changes up ok. Has anybody experienced this fault? Crying or Very sad RRS2 HSE Chile Red
1955 Morris Minor lovingly fitted every nut and bolt
Post #545084 Sun Jan 07 2018 6:46pm
geoffsnook
No sorry but this will push you back to the top Laughing
Post #545122 Sun Jan 07 2018 8:34pm
cmec
United Kingdom 2013 Range Rover Sport SDV6 HSE Firenze Red
Hi had a similar problem with my previous model sport, dealers explaination was that they did something with the control software and that fixed it. Whatever it was it worked. Thumbs Up
Post #545169 Mon Jan 08 2018 11:08am
geoffsnook
Then it may need a software update from dealer or through an IDD tool Thumbs Up
Post #545170 Mon Jan 08 2018 11:14am
Paddi
The older L320 model can have a known fault with gearbox not changing up that is related to failed or incorrectly fitted stop/tail bulbs (makes the car think it is braking when it isn't).
Have you had anything done to the rear lights recently? 2008 MY Java Black TDV8 HSE
Post #545180 Mon Jan 08 2018 1:42pm
Welshian
Wales
Thanks for the info Paddi, the car went in its annual service in Nov but prior to that no probs and no work on the brake lights either, although upgrading the front headlights would't go amiss. Makes you think Question RRS2 HSE Chile Red
Post #545366 Tue Jan 09 2018 10:42pm
Eaters
Ahh. I see Exclamation
That explains it. Couldn’t understand why a bulb could cause so many random faults in the rest of the car’s systems. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #545481 Wed Jan 10 2018 10:00pm
