Home > Technical > Battery problem |
Signori Member Since: 30 Jan 2017 Location: Baildon, West Yorkshire Posts: 33 |
Hi everyone,
Thu Dec 28 2017 9:45am |
How old is the current battery |
Thu Dec 28 2017 10:18am |
Not sure tbh, I've only had the car 18 months. |
Thu Dec 28 2017 10:40am |
Change it then if you don’t know how d it is |
Thu Dec 28 2017 11:02am |
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 |
If your going to get a new battery It might be worth checking out Tanya batteries on their eBay site http://stores.ebay.co.uk/Tayna-Batteries, you can use the 20% off discount code until 6pm tonight PNY2018. if you do a search on here or the Disco3 forums you will see a lot of people have used them. I suspect it will be a bit cheaper than from Halfords. |
Thu Dec 28 2017 3:24pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
I had a starting problem and so replaced the battery. It turned out however that it was the alternator that was u/s and has to be replaced. So I suggest before replacing the battery, get the alternator checked. No good throwing good money after bad.
Thu Dec 28 2017 10:24pm |
