![]() | Home > Technical > Battery problem |
Signori Member Since: 30 Jan 2017 Location: Baildon, West Yorkshire Posts: 33 ![]() ![]() ![]() |
Hi everyone,
How old is the current battery |
Not sure tbh, I've only had the car 18 months. |
Change it then if you don’t know how d it is |
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 ![]() ![]() ![]() |
If your going to get a new battery It might be worth checking out Tanya batteries on their eBay site http://stores.ebay.co.uk/Tayna-Batteries, you can use the 20% off discount code until 6pm tonight PNY2018. if you do a search on here or the Disco3 forums you will see a lot of people have used them. I suspect it will be a bit cheaper than from Halfords. |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
I had a starting problem and so replaced the battery. It turned out however that it was the alternator that was u/s and has to be replaced. So I suggest before replacing the battery, get the alternator checked. No good throwing good money after bad.
