Home > Technical > Battery problem
Signori
Battery problem
Hi everyone,
The last couple of weeks i've had problems getting my 2008 RRS started. The battery seems to be going flat, but there's no warnings ect on the dash. Do you think it's only the battery thats dead or possibly something else?
The battery is this one http://www.halfords.com/motoring/bulbs-bla...sa+battery
Is this the correct size/power for the car? I'll pick another up from Halfords today if it is
Thanks
Post #544202 Thu Dec 28 2017 9:45am
geoffsnook
How old is the current battery Thumbs Up
Post #544209 Thu Dec 28 2017 10:18am
Signori
Not sure tbh, I've only had the car 18 months.
Post #544215 Thu Dec 28 2017 10:40am
geoffsnook
Change it then if you don’t know how d it is Thumbs Up
Post #544221 Thu Dec 28 2017 11:02am
david007
United Kingdom 2011 Range Rover Sport SDV6 SE Vesuvius Orange
If your going to get a new battery It might be worth checking out Tanya batteries on their eBay site http://stores.ebay.co.uk/Tayna-Batteries, you can use the 20% off discount code until 6pm tonight PNY2018. if you do a search on here or the Disco3 forums you will see a lot of people have used them. I suspect it will be a bit cheaper than from Halfords.
Post #544249 Thu Dec 28 2017 3:24pm
Eaters
I had a starting problem and so replaced the battery. It turned out however that it was the alternator that was u/s and has to be replaced. So I suggest before replacing the battery, get the alternator checked. No good throwing good money after bad.
My original 21 months old Bosch battery had been flattened by the bad alternator but is still going strong and working well with the new alternator in spite of these current low temperatures. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #544286 Thu Dec 28 2017 10:24pm
