Home > General > Engine management light on now , what next !!!
Alfie
England 2008 Range Rover Sport TDV8 HSE Lux Java Black
So on Friday the tailgate gets stuck in the closed position which thanks to this great forum I sorted without the cost or visit to the stealers which I am extreamily grateful . The next day on a short journey the Engine management light comes on and stays on until I get home . My only thought at this point is to check the fuses because when I was trying to sort the tailgate problem I checked the fuses for it and I immediately thought maybe I've caught something within the fuse housing !! Anyhow as a matter of course I decide to replace the two fuses that have the same picture as the display on the dash ( engine solouett) and hey presto it's cured ........so far anyway . The two fuses I took out seemed ok but I changed them anyway and now the car starts up and the amber light goes out as it should ! Could this be a coincidence and maybe something is lurking round the corner ?? Hope not
Post #540290 Mon Nov 06 2017 6:40pm
drdelrrs
I'd try the 'hard reset' and see if rebooting the system clears a potential glitch in the software - its large based on a Microsoft core.
Battery disconnect wait 30seconds and reconnect.
Post #540299 Mon Nov 06 2017 7:44pm
Socast
To do a reset of the system you remove the positive a negative leads from the battery and then touch the two together, purging any residual power in the system, leaving the leads disconnected over night isn't as effective as the above technique. Thumbs Up
Post #540436 Thu Nov 09 2017 2:57pm
Alfie
Ok will give that a try because today the EML came on again but when I got home I left it for a couple of hours and the light has gone off again but I will try the hard reset routine if it occurs again as I suspect it will ! The car is at the stealers on Thursday for front ARB BUSHES , not sure if to mention what's been going on this last 2 weeks in case they spend time checking stuff out then charging me a small fortune Big Cry
Post #540674 Sun Nov 12 2017 7:38pm
Bodsy
Site Sponsor
Eml coming on is almost always sticking EGR valves. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #540691 Sun Nov 12 2017 10:44pm
Alfie
Hi Bodsy , is it always a case of renewing EGR valves or is there a way of fixing ? ( if you decide not to blank them )
Post #540704 Mon Nov 13 2017 5:32am
Disco_Mikey
Blank or Renew Thumbs Up
Post #540738 Mon Nov 13 2017 7:52am
Alfie
Fault codes read and has come up as suspected EGR Valves defect . So far the performance from the car has not changed ( no loss of power and no black smoke out the back ) have been advised as not to worry about them yet , strangely the EML has gone out and been off for passed 3 days
Post #541268 Sat Nov 18 2017 3:20pm
