Home > General > Strange alarm behaviour. |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
Father Jack...love that username Dougal might be better though Steve. |
Fri Oct 20 2017 3:42pm |
I have been known to use the odd or two, and like a wee beer now and then, so it is fairly appropriate ! |
Fri Oct 20 2017 3:46pm |
Steve. |
Sat Oct 21 2017 11:49am |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
https://www.ebay.co.uk/itm/YUE500150-Range...2749.l2649
Fri Nov 03 2017 7:38am |
If it was the switch, wouldn`t it go off as soon as I locked it....and also, wouldn`t I have a bonnet open message on the display? Steve. |
Fri Nov 03 2017 8:47am |
No, not always. They have a tendency to be working one minute, and then causing alarms at random times when locked. Very simple to change, you tube vids available if you do a search. |
Fri Nov 03 2017 11:56am |
Ah right ok matey. I`ve just had a quick look after washing it...I assume the switch is behind the grill?
Fri Nov 03 2017 1:15pm |
Yep, take the grille off, the switch is on the offside catch (drivers side) Whip the two torx screws out to loosen the catch assy, don’t lose the little plate. Unplug the lead to the switch which is under the catch, using a small screwdriver, prize out the knackered switch. Fit the new switch to the catch and refit the plug. Using the witness marks to help you align the catch assy, fit back on to the body not forgetting to fit the little plate.
Fri Nov 03 2017 1:25pm |
Nice one, thanks. Just ordered one Steve. |
Fri Nov 03 2017 1:27pm |
No problem, happy to help Steve. PS, did my front discs/pads this morning. Easy job and so far, touch wood, no squealing dragging brakes. |
Fri Nov 03 2017 1:34pm |
After having my rears done, I get a rotational squeak now and then, drives me mad Steve. |
Fri Nov 03 2017 2:39pm |
Changed the switch just now. Probably would have been ok just to give it a good clean but, it`s swapped now. Fingers crossed that`s fixed it. This is what the old one looked like... Steve. |
Fri Nov 10 2017 1:44pm |
Bullybrighton Member Since: 18 Nov 2017 Location: Maidstone Posts: 8 |
Did changing the catch solve it?
Thu Nov 23 2017 10:37pm |
Hi mate. Yeah it seems to have worked. Takes about 10 mins to change,
Thu Nov 23 2017 10:43pm |
