Home > General > Strange alarm behaviour.
Page 2 of 3 <123>
Cymruambyth
Wales
Father Jack...love that username Laughing Dougal might be better though Very Happy Steve.
Post #538803 Fri Oct 20 2017 3:42pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
Cool I have been known to use the odd Censored or two, and like a wee beer now and then, so it is fairly appropriate !
Post #538804 Fri Oct 20 2017 3:46pm
Cymruambyth
Wales
Laughing Thumbs Up Steve.
Post #538853 Sat Oct 21 2017 11:49am
Cymruambyth
Wales
Andy K wrote:
bet it still goes off Laughing
Horn signals something left open. Door/boot/bonnet
Why does my neighbours f-ing 2015 Merc sound the horn every time its locked?
I'm sure its against regulators to do that these days
You were right Laughing it`s started doing it again Rolling Eyes Steve.
Post #540043 Thu Nov 02 2017 11:17pm
GodivaNige
https://www.ebay.co.uk/itm/YUE500150-Range...2749.l2649
10 minutes to replace Thumbs Up
Post #540049 Fri Nov 03 2017 7:38am
Cymruambyth
Wales
If it was the switch, wouldn`t it go off as soon as I locked it....and also, wouldn`t I have a bonnet open message on the display? Steve.
Post #540054 Fri Nov 03 2017 8:47am
GodivaNige
No, not always. They have a tendency to be working one minute, and then causing alarms at random times when locked. Very simple to change, you tube vids available if you do a search. Thumbs Up
Post #540064 Fri Nov 03 2017 11:56am
Cymruambyth
Wales
Ah right ok matey. I`ve just had a quick look after washing it...I assume the switch is behind the grill?
edit...found a video Thumbs Up Steve.
Post #540069 Fri Nov 03 2017 1:15pm
GodivaNige
Yep, take the grille off, the switch is on the offside catch (drivers side) Whip the two torx screws out to loosen the catch assy, don’t lose the little plate. Unplug the lead to the switch which is under the catch, using a small screwdriver, prize out the knackered switch. Fit the new switch to the catch and refit the plug. Using the witness marks to help you align the catch assy, fit back on to the body not forgetting to fit the little plate.
Voila Thumbs Up
Post #540070 Fri Nov 03 2017 1:25pm
Cymruambyth
Wales
Nice one, thanks. Just ordered one Thumbs Up Steve.
Post #540071 Fri Nov 03 2017 1:27pm
GodivaNige
No problem, happy to help Steve. PS, did my front discs/pads this morning. Easy job and so far, touch wood, no squealing dragging brakes. Thumbs Up
Post #540072 Fri Nov 03 2017 1:34pm
Cymruambyth
Wales
After having my rears done, I get a rotational squeak now and then, drives me mad Sad Steve.
Post #540074 Fri Nov 03 2017 2:39pm
Cymruambyth
Wales
Changed the switch just now. Probably would have been ok just to give it a good clean but, it`s swapped now. Fingers crossed that`s fixed it.
This is what the old one looked like...
 Steve.
Post #540526 Fri Nov 10 2017 1:44pm
Bullybrighton
Did changing the catch solve it?
I have a my2010 and was told that if it is the catch, it will beep when locking? Mine doesn’t beep when locking but randomly (and annoyingly) goes off fairly regularly.
Any ideas or should I just swap the switch and keep them crossed?
Post #541725 Thu Nov 23 2017 10:37pm
Cymruambyth
Wales
Hi mate. Yeah it seems to have worked. Takes about 10 mins to change,
Mine didn't beep on locking, only after the alarm went off and I silenced it. Steve.
Post #541727 Thu Nov 23 2017 10:43pm
Page 2 of 3 <123>
