![]() | Home > In Car Electronics > Battery going flat |
What sort of use does your car get in terms of daily use? Is it mostly short runs?
ssandps Member Since: 22 Nov 2016 Location: Staines Posts: 23 ![]() ![]() ![]() |
Hi thanks , yes it does only short trips during the week so i will get a smart charger . Also when we got the car the boot light was disconnected , I reconnected it and replaced the bulb . I have now disconnected it again , will also try the switch as you said .
Is the upper tailgate switch the release switch ? Also how is it accessed?
Yes, it is the one with the rubber cover. Ideally, open the upper tailgate, remove the plastic trim and push out the switch from the inside. Alternatively CAREFULLY lever out the switch from the outside but this risks scratching the surrounding bodywork. It will probably be corroded and a bit reluctant to come out cleanly. If you search the site for 'upper tailgate switch you'll find descriptions and pictures of how to do it. 2008 MY Java Black TDV8 HSE
Thanks for the advise I will let you know how I get on . |
Brutus Member Since: 10 Nov 2015 Location: Cambridgeshire Posts: 67 ![]() ![]() ![]() |
ssandps,
I did change the upper tailgate switch which was corroded , however if left for more than a couple of days it is still going flat . So I have purchased a smart charger and tend to charge it on a sunday when it mainly does not get used . So I still don't know what else it could be ?
Alfa Rover Member Since: 15 Dec 2016 Location: Vancouver Posts: 19 ![]() ![]() |
Hi, had the same problem. turned out to be my starter motor. a good shop will be able to confirm the current draw using an amp clamp and pin point the problem. i did it myself because i love a challenge.
Also when you park it do you lower it to access height? This is really important if you you don’t use the car a lot as it will force all the electronics to go into sleep mode, if you leave it in normal height then the electronics will only hibernate and will be looking for your key fob all the time.
