Home > In Car Electronics > Battery going flat |
What sort of use does your car get in terms of daily use? Is it mostly short runs?
Tue Feb 07 2017 9:32pm |
ssandps Member Since: 22 Nov 2016 Location: Staines Posts: 23 |
Hi thanks , yes it does only short trips during the week so i will get a smart charger . Also when we got the car the boot light was disconnected , I reconnected it and replaced the bulb . I have now disconnected it again , will also try the switch as you said .
Tue Feb 07 2017 10:03pm |
Is the upper tailgate switch the release switch ? Also how is it accessed?
Tue Feb 07 2017 10:17pm |
Yes, it is the one with the rubber cover. Ideally, open the upper tailgate, remove the plastic trim and push out the switch from the inside. Alternatively CAREFULLY lever out the switch from the outside but this risks scratching the surrounding bodywork. It will probably be corroded and a bit reluctant to come out cleanly. If you search the site for 'upper tailgate switch you'll find descriptions and pictures of how to do it. 2008 MY Java Black TDV8 HSE
Tue Feb 07 2017 11:02pm |
Thanks for the advise I will let you know how I get on . |
Wed Feb 08 2017 7:32pm |
Brutus Member Since: 10 Nov 2015 Location: Cambridgeshire Posts: 67 |
ssandps,
Thu Apr 20 2017 8:14am |
I did change the upper tailgate switch which was corroded , however if left for more than a couple of days it is still going flat . So I have purchased a smart charger and tend to charge it on a sunday when it mainly does not get used . So I still don't know what else it could be ?
Thu Apr 20 2017 6:34pm |
Alfa Rover Member Since: 14 Dec 2016 Location: Vancouver Posts: 19 |
Hi, had the same problem. turned out to be my starter motor. a good shop will be able to confirm the current draw using an amp clamp and pin point the problem. i did it myself because i love a challenge.
Fri Nov 03 2017 8:11am |
Also when you park it do you lower it to access height? This is really important if you you don’t use the car a lot as it will force all the electronics to go into sleep mode, if you leave it in normal height then the electronics will only hibernate and will be looking for your key fob all the time.
Fri Nov 03 2017 12:46pm |
