![]() | Home > General > RRS V Discovery3 |
I would say having moved from a disco 3 to a RRS that it feels a bit smaller and mine is a bit lower on the drivers seat but mine is the supercharged but it is every bit as comfortable probably a lot more |
nebc100 Member Since: 27 Aug 2017 Location: Altlinster Posts: 113 ![]() ![]() ![]() |
Hello Murphy,
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
RRS 2006:
Sorry, but I have found other values for the Discovery:
Did not say the supercharged was actually lower than a normal range rover sport but did say feels smaller and lower |
Sorry Geoffsnook, I misunderstood you. |
No apologies needed here - just copied and pasted from LR websites. Barrie.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
the suspension height calibrations are slightly different on the RRS v D3 |
murphy Member Since: 04 Sep 2017 Location: London Posts: 22 ![]() ![]() ![]() |
Thank you all for the reply's
It can't be 10 inches wider. It's not possible! |
I think that the difference is actually because some measurements are including mirrors, and some without. |
Yes nebc100, that is probably the reason |
The difference in width is minimal - inside width is basically the same. The RRS is shorter because the wheelbase is shorter. The drivers sear sits basically the same in both cars - differences are in adjustments available in different trim levels. My seat is adjustable up and down as are some D3 seats. Driving position is the same but feels different because of the upright nature of the D3 dash. 07MY RRS TDV6
