![]() | Home > Maintenance & Modifications > Vehicle battery replacement. |
You need to fill in your vehicle details
A 2007 TDV8 doesn't need AGM. 019 is the correct battery size. Be careful, as even in the correct sizing you can get small differences in the base of the battery that clash with the box in the engine bay. I had this with the Yuasa one I got from Halfords. Easy enough to remedy but needs to be considered. 2012 SDV6 - it's missing a couple of cylinders
Lonerangerv8 Member Since: 16 Sep 2015 Location: Cheshire Posts: 83 ![]() ![]() ![]() |
Would fitting the AGM type battery be ok anyway?
Unlock the vehicle, pop the bonnet, go and make a cuppa for 10 minutes. This lets the various ECUs go back to sleep. Disconnect black then red. Battery is a bit tight coming out and going in and is heavy so be careful. The engine and transfer box ECUs are in an enclosure at the rear of the battery box so take care not to smack them with the new battery. Connect red then black. Make sure the hydrogen vent pipe goes on the new battery and isn't pinched by the battery. 2012 SDV6 - it's missing a couple of cylinders
Vehicle doors shut or open ?? |
Doesn't matter as far as I know but I'd close the doors. 2012 SDV6 - it's missing a couple of cylinders
Have an AGM battery fitted to mine for years and no problems. 2008 MY Java Black TDV8 HSE ![]() |
