Home > Maintenance & Modifications > Vehicle battery replacement.
Lonerangerv8
United Kingdom 2007 Range Rover Sport TDV8 HSE Santorini Black
Is the Bosch or Duracell 019 size battery the correct fitment for the car ?
I have been advised that the larger 110ah 020 battery will not fit without alterations to the tray. Is this correct.?
Also when changing the battery over what is the correct procedure.
Any advice welcomed.
Post #534063 Tue Aug 29 2017 10:26pm
SRE
Spain
You need to fill in your vehicle details
Remember Land Rover only Fit AGM Batteries. Loads of info on here, just do a search AGM Battery In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #534076 Wed Aug 30 2017 9:38am
A 2007 TDV8 doesn't need AGM. 019 is the correct battery size. Be careful, as even in the correct sizing you can get small differences in the base of the battery that clash with the box in the engine bay. I had this with the Yuasa one I got from Halfords. Easy enough to remedy but needs to be considered. 2012 SDV6 - it's missing a couple of cylinders
Post #534077 Wed Aug 30 2017 9:55am
Lonerangerv8
Battery replacement
Would fitting the AGM type battery be ok anyway?
Is there any set procedure that needs to be done before and after changing the battery ??
Post #534088 Wed Aug 30 2017 12:12pm
Unlock the vehicle, pop the bonnet, go and make a cuppa for 10 minutes. This lets the various ECUs go back to sleep. Disconnect black then red. Battery is a bit tight coming out and going in and is heavy so be careful. The engine and transfer box ECUs are in an enclosure at the rear of the battery box so take care not to smack them with the new battery. Connect red then black. Make sure the hydrogen vent pipe goes on the new battery and isn't pinched by the battery. 2012 SDV6 - it's missing a couple of cylinders
Post #534101 Wed Aug 30 2017 1:57pm
Lonerangerv8
Battery replacement
Vehicle doors shut or open ??
Post #534102 Wed Aug 30 2017 2:18pm
Doesn't matter as far as I know but I'd close the doors. 2012 SDV6 - it's missing a couple of cylinders
Post #534103 Wed Aug 30 2017 2:32pm
Paddi
Re: Battery replacement
Have an AGM battery fitted to mine for years and no problems. 2008 MY Java Black TDV8 HSE
Post #534109 Wed Aug 30 2017 3:49pm
