Home > Technical > Fault Codes P006A-00 & P1247-00, Restricted Performance
Mr M
Intermittently, I get a red warning triangle on my dash and a 'Restricted Performance' warning notification and the car goes into 'limp mode'. When I turn the engine off and come back after 5 or 10 minutes, everything is back to normal and the warning notifications and 'limp mode' have gone. During normal driving, the above does not seem not to happen anywhere near as much, but if I drive the car a bit harder ie accelerate harder developing higher revs, it seems to force the car into 'Restricted Performance'.
A diagnostic has given the following fault codes:
P006A-00 / Temporary / Manifold Absolute Pressure - mass or volume air flow correlation &
P1247-00 / Intermittent / Turbocharger boost pressure low
Can anyone advise the likely cause(s) of my problem based on the code reader information and what needs to be done to fix it?
Post #533286 Sun Aug 20 2017 10:44am
This is from workshop manual, if you can decipher any of it and what it means it may help.
P006A-
00
MAP - Mass or Volume Air
Flow Correlation - No sub
type information
Intake air system,
high pressure boost
leak bank 1
Intake air system,
high pressure boost
If this DTC is logged with P1247-00,
P0402-00 & P00BF-07, suspect intake air
system, high pressure boost leak bank 1
suspect intake air system, high pressure
leak bi-turbo mode
bank 2
Intake air system, low
pressure boost leak
bank 1
pressure boost leak
bank 2
boost leak bi-turbo mode bank 2
If this DTC is logged with P00BE-07 &
P0401-00, suspect intake air system, low
If this DTC is logged with P00BC-00,
suspect intake air system, low pressure
boost leak bank 2
Using the manufacturer approved
diagnostic system perform the (Turbo,
EGR and air path dynamic test) routine
Post #533296 Sun Aug 20 2017 11:14am
Mr M
Thanks Col,
Lots of information there. I'm not mechanical so I don't really have any idea what any of that means! Confused Hopefully others on here might be able to interpret it and advise.
Post #533301 Sun Aug 20 2017 11:27am
Dawen35
Wales 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
What year is the car, the reason for asking is my2010 started with similar fault codes and is currently having its dpf filter removed as it was blocked solid
Post #533324 Sun Aug 20 2017 4:12pm
Mr M
It's the same as yours, a 2010 3.0 ltr TDV6. How did you determine that it was the DPF that needed to be replaced?
Post #533325 Sun Aug 20 2017 4:24pm
Dawen35
The garage did, it was totally blocked solid. Symptoms of the drive was red triangle intermittently for a week and then total loss of power and a high pitch squeak on the last day
Post #533326 Sun Aug 20 2017 4:27pm
Disco_Mikey
Could be a split boost hose or manifold. Both very common Thumbs Up
Post #533331 Sun Aug 20 2017 5:16pm
Mr M
Thanks. Are both of these components easily accessible for me to check? Sorry but i'm not that mechanically minded so any pointers as to where both items are located so that I can check them for splits/leaks etc would be appreciated.
Post #533337 Sun Aug 20 2017 6:10pm
Mr M
Update - The manifold has a split in it Shocked so a new one's been ordered and it's being fitted on Wednesday. Hopefully then, everything should be back to normal.
Post #533822 Fri Aug 25 2017 8:21pm
Mr M
Further update - The manifold has been changed but I am still getting the same issues. The garage reckons its one of the EGR valves. They've suggested removing it, giving it a good clean and then re-fitting it to see if that sorts it out. Has anyone had any success with cleaning these as opposed to just replacing them?
I've also pm'd Bodsy to see if he wants to blank both EGR's for me.
Post #536294 Sun Sep 24 2017 10:05am
Oldandconfused
Can someone educate me please, I have been led to believe that the 3.0ltr TDV6 has vacuum operated EGR valves that are far less of a problem than the electronically activated ones on the 2.7.
My old D3 was easily blanked and that post 2007 2.7's needed a software patch. Do we need a patch/emulator on the 3.0ltr?
Sorry to hi-jack your thread, but it may be helpful to know if faulty EGR's are as common on this engine, and how owners have resolved it.
Post #536295 Sun Sep 24 2017 10:24am
Disco_Mikey
3.0 cannot blank the EGR, as they are needed as part of the DPF regeneration...
Personally, never seen a faulty 3.0 EGR valve yet...
Post #536304 Sun Sep 24 2017 11:23am
Mr M
Ok thanks.
I had a new manifold fitted recently as the old one had a 2" split in it. But the car was still 'juddery' when starting off in lower gears and of a morning, i would get plumes of grey smoke coming out of the back. When I get going the car is still 'juddery' in the lower gears and I will eventually get a red warning triangle on my dash and a 'Restricted Performance' warning notification and the car goes into 'limp mode'. Following this, the car drives better but with little performance. If I then turn the engine off and come back after 5 or 10 minutes, everything is back to normal but then the same cycle is repeated.
If it's not the EGR valve, any ideas what else my problem is most likely to be?
Is it worth getting the EGR removed and cleaning it anyway, just to eliminate that as a possible cause? How long should a garage take to remove, clean and refit one of the EGR's
Post #536307 Sun Sep 24 2017 12:07pm
Disco_Mikey
What fault codes have returned?
Post #536313 Sun Sep 24 2017 1:46pm
Mr M
I've only got a cheapo fault code reader but i've plugged it in and it's come-up with Code P006A which was one of the two codes that I was getting originally. When the garage replaced the manifold, they checked the MAF and said that was ok. Is there anything else that it is likely to be other than the EGR?
Post #536316 Sun Sep 24 2017 2:28pm
