Home > Technical > Fault Codes P006A-00 & P1247-00, Restricted Performance |
Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407 |
You need to get the stored codes removed and then read with correct equipment, LR garage or GAP IID Tool BT or similar.
Mon Sep 25 2017 12:54am |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 |
i had the same problems, till it got worse and the DPF anex catalyst converter melted down.
Mon Sep 25 2017 3:48pm |
johnhorgan Member Since: 25 Sep 2019 Location: Nelson Posts: 2 |
Did you ever figure out the problem? I have the same. |
Tue Aug 08 2023 9:06pm |
