![]() | Home > Faults & Fixes > Sorry another central locking issue from a newbie |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Is the battery healthy?
Sionr Member Since: 13 Jul 2017 Location: N.wales Posts: 9 ![]() ![]() ![]() |
Hi thanks for the reply I'll go plug it in now and try that thank you |
hard2beat2014 Member Since: 14 Jun 2014 Location: cambridge Posts: 63 ![]() ![]() ![]() |
cant see why the battery would cause central locking problems |
I'll try anything before taking it to the dealers
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 ![]() ![]() |
I think that's just nerves! ![]() |
Battery recharge didn't work thinking of ordering anew fob battery |
Sorry it didn't work. Hope it was worth a go though. I'm with you; anything to avoid the dealer Robin
Well like I said to the Mrs maybe it's the fob battery knackered and the two front doors never locked I mean I never actually checked if they were locked after pressing the button
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
:EDIT: Sorry, didn't read properly |
The fob isn't doing anything |
If I take the key apart and check the voltage in the battery it will rule out that atleast correct? Or no |
Well I managed to split my fob case without damaging it (poor previous fix by someone) and the battery wasn't connected on one side little temporary solder fix and it's working again
If you open the key you can test the battery yes, but the voltage on the battery doesn't dictate if the key works or not. You will also need to order a new case if you open the key, but before doing that, see if your local garage has a key tester, that will tell you if the key is emiting a signal and takes seconds to do.
makes sense I do need a spare |
