Home > Faults & Fixes > Sorry another central locking issue from a newbie |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 |
Is the battery healthy?
Wed Jul 19 2017 7:45pm |
Sionr Member Since: 13 Jul 2017 Location: N.wales Posts: 9 |
Hi thanks for the reply I'll go plug it in now and try that thank you |
Wed Jul 19 2017 8:16pm |
hard2beat2014 Member Since: 14 Jun 2014 Location: cambridge Posts: 63 |
cant see why the battery would cause central locking problems |
Wed Jul 19 2017 8:22pm |
I'll try anything before taking it to the dealers
Wed Jul 19 2017 8:29pm |
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 |
I think that's just nerves! |
Wed Jul 19 2017 8:50pm |
Battery recharge didn't work thinking of ordering anew fob battery |
Fri Jul 21 2017 8:52am |
Sorry it didn't work. Hope it was worth a go though. I'm with you; anything to avoid the dealer Robin
Fri Jul 21 2017 8:54am |
Well like I said to the Mrs maybe it's the fob battery knackered and the two front doors never locked I mean I never actually checked if they were locked after pressing the button
Fri Jul 21 2017 9:02am |
:EDIT: Sorry, didn't read properly
Fri Jul 21 2017 10:16am |
The fob isn't doing anything |
Fri Jul 21 2017 10:39am |
If I take the key apart and check the voltage in the battery it will rule out that atleast correct? Or no |
Fri Jul 21 2017 10:41am |
Well I managed to split my fob case without damaging it (poor previous fix by someone) and the battery wasn't connected on one side little temporary solder fix and it's working again
Fri Jul 21 2017 10:55am |
If you open the key you can test the battery yes, but the voltage on the battery doesn't dictate if the key works or not. You will also need to order a new case if you open the key, but before doing that, see if your local garage has a key tester, that will tell you if the key is emiting a signal and takes seconds to do.
Fri Jul 21 2017 10:59am |
makes sense I do need a spare |
Fri Jul 21 2017 11:00am |
