Home > Wheels & Tyres > What 19 inch rims will fit RRS with Brembo brakes |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
Elsewhere on the forum you will see my add for the sale of 4 19 inch wheels and tyres. Only selling because they wont fit over my Brembo brake callipers.
Thu Feb 16 2017 10:41am |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1052 |
These
Thu Feb 16 2017 11:51am |
Cheers guys
Thu Feb 16 2017 1:06pm |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 |
That's 860kg per wheel x 4 = 3440 kg 61 AB 5.0 supercharged rocket
Thu Feb 16 2017 8:04pm |
Thanks ShooterNeil. I was hoping that that was the case Robin
Thu Feb 16 2017 10:46pm |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 311 |
Check your axle weights on the sticker under the bonnet, the rating for the pair of wheels needs to be more than the max weight for that axle. In this case you'll be way over, but it's useful to know. It's recommended to have 25% over per wheel as a safety margin too. |
Thu Feb 16 2017 11:43pm |
New image coming...
Fri Feb 17 2017 8:20am |
It tells anyone reading the thread what your car's VIN is.................. suggest you edit the photo to avoid cloning
Fri Feb 17 2017 12:10pm |
Thanks Tim. I've removed the image for now. Will repost when I'm home. Thanks for the advice👌
Fri Feb 17 2017 1:21pm |
I'm resurrecting this post as my manic few months has calmed down a bit and I'm now looking to sort out my winter wheels.
Thu Jun 01 2017 8:53pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8988 |
Gross Vehicle Weight: 3175kg Max Train weight (vehicle plus trailer): 6675kg Max front axle load: 1540kg Max rear axle load: 1710kg Note that each is a maximum so you can't add max allowable front and rear axles as that would exceed the GVW. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thu Jun 01 2017 9:26pm |
Hi Robin,
Thu Jun 01 2017 9:35pm |
Tomorrow I will look through all my RRS brochures and see if I can find the style/ design codes for the wheels I posted the photos of 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Jun 01 2017 9:45pm |
Thu Jun 01 2017 9:48pm |
