![]() | Home > Wheels & Tyres > What 19 inch rims will fit RRS with Brembo brakes |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Elsewhere on the forum you will see my add for the sale of 4 19 inch wheels and tyres. Only selling because they wont fit over my Brembo brake callipers.
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
These
Cheers guys
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 ![]() ![]() ![]() |
That's 860kg per wheel x 4 = 3440 kg 61 AB 5.0 supercharged rocket
Thanks ShooterNeil. I was hoping that that was the case Robin
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 317 ![]() ![]() ![]() |
Check your axle weights on the sticker under the bonnet, the rating for the pair of wheels needs to be more than the max weight for that axle. In this case you'll be way over, but it's useful to know. It's recommended to have 25% over per wheel as a safety margin too. |
New image coming...
It tells anyone reading the thread what your car's VIN is.................. suggest you edit the photo to avoid cloning
And these that I ran the TDV8 on with Pirelli Ice and Snow tyres [URL=]
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 2018 Melting Silver Mini Countryman PHEV - soon to be replaced 2015MY Corris Grey SDv6 HSE Dynamic, the best car I have ever owned, totally reliable only a cou0le of rattles in 3 years, now no longer in my care Also in my garage is a 1996 TDi300 Defender 90 County HT made into a fake CSW |
Thanks Tim. I've removed the image for now. Will repost when I'm home. Thanks for the advice👌
I'm resurrecting this post as my manic few months has calmed down a bit and I'm now looking to sort out my winter wheels.
Thanks for your help with your photos Tim. However, its not the easiest thing in the world to search for new wheels for my 19 inch tyres from just a picture. Are you saying that if they look like your pics then they will definitely fit? Does anyone know if wheels have a type (or model?) reference number (or a name or description) and if so what Tim's wheels would be? Also has anyone any idea why the ones I've got don't fit in spite of general advice from the forum stating that 19's will fit on my TDV8 over Brembos. My ones clearly don't - after trying them there was a terrible graunching sound and the RRS hardly moved. I am guessing that the key problem is the offset which I believe is shown in this picture
But I am not an expert on wheels by any means And I am guessing that this is the model number of the wheel:
Any thoughts gladly received. Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
Gross Vehicle Weight: 3175kg Max Train weight (vehicle plus trailer): 6675kg Max front axle load: 1540kg Max rear axle load: 1710kg Note that each is a maximum so you can't add max allowable front and rear axles as that would exceed the GVW. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Hi Robin,
Tomorrow I will look through all my RRS brochures and see if I can find the style/ design codes for the wheels I posted the photos of 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
