Home > Wheels & Tyres > What 19 inch rims will fit RRS with Brembo brakes
Page 1 of 3 123>
Eaters
Elsewhere on the forum you will see my add for the sale of 4 19 inch wheels and tyres. Only selling because they wont fit over my Brembo brake callipers.
Does anyone know what 19 inch wheels will fit as presumably I could swap the tyres over. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #517940 Thu Feb 16 2017 10:41am
Buckster
I would say the snowflake 19s as thats around the right time for TDV8s and Brembos
But you need definite confirmation from other members that run them as im not 100% sure Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #517943 Thu Feb 16 2017 11:25am
Pufftmw
These
Somewhere behind there are Brembos...
Post #517946 Thu Feb 16 2017 11:51am
Eaters
Cheers guys
Any idea what part of model number they are?
Also, having had to look into wheels in a lot more detail, I am a bit concerned that the ones I have appear to suggest a weight limit of 860kg (as suggested by this picture of the inside) although I have no idea if I am reading these codes correctly.
Is this correct for the RRS? Robin
Gone:
MGZTT 190 2.5
Post #517957 Thu Feb 16 2017 1:06pm
ShooterNeil
England 2007 Range Rover Sport TDV8 HSE Java Black
That's 860kg per wheel x 4 = 3440 kg 61 AB 5.0 supercharged rocket
07 HSE TDV8 with lots of toys EGR removed BAS remap
56 HSE WAS FULL OF PROBLEMS
Post #517987 Thu Feb 16 2017 8:04pm
Eaters
Thanks ShooterNeil. I was hoping that that was the case Robin
Gone:
MGZTT 190 2.5
Post #518006 Thu Feb 16 2017 10:46pm
d-9
Check your axle weights on the sticker under the bonnet, the rating for the pair of wheels needs to be more than the max weight for that axle. In this case you'll be way over, but it's useful to know. It's recommended to have 25% over per wheel as a safety margin too.
Post #518012 Thu Feb 16 2017 11:43pm
Eaters
New image coming...
Here it is:
Is this the sticker you're referring to D-9.
What does it tell me? Robin
Gone:
MGZTT 190 2.5
Post #518026 Fri Feb 17 2017 8:20am
Tim in Scotland
It tells anyone reading the thread what your car's VIN is.................. suggest you edit the photo to avoid cloning
LRC798 is the paint code
Wheels: IIRC these will fit - they are from a Disco3 that I ran on my TDV8 with GoodYear Eagle MTRs
[URL=]
[/URL]
And these that I ran the TDV8 on with Pirelli Ice and Snow tyres
[URL=]
[/URL]
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #518054 Fri Feb 17 2017 12:10pm
Eaters
Thanks Tim. I've removed the image for now. Will repost when I'm home. Thanks for the advice👌
New image now posted above
Robin Robin
Gone:
MGZTT 190 2.5
Post #518063 Fri Feb 17 2017 1:21pm
Eaters
I'm resurrecting this post as my manic few months has calmed down a bit and I'm now looking to sort out my winter wheels.
This is what I currently have four of:
Thanks for your help with your photos Tim. However, its not the easiest thing in the world to search for new wheels for my 19 inch tyres from just a picture. Are you saying that if they look like your pics then they will definitely fit? Does anyone know if wheels have a type (or model?) reference number (or a name or description) and if so what Tim's wheels would be?
Also has anyone any idea why the ones I've got don't fit in spite of general advice from the forum stating that 19's will fit on my TDV8 over Brembos. My ones clearly don't - after trying them there was a terrible graunching sound and the RRS hardly moved.
I am guessing that the key problem is the offset which I believe is shown in this picture
But I am not an expert on wheels by any means
And I am guessing that this is the model number of the wheel:
Any thoughts gladly received. Robin
Gone:
MGZTT 190 2.5
Post #527388 Thu Jun 01 2017 8:53pm
Eaters wrote:
New image coming...
Here it is:
Gross Vehicle Weight: 3175kg
Max Train weight (vehicle plus trailer): 6675kg
Max front axle load: 1540kg
Max rear axle load: 1710kg
Note that each is a maximum so you can't add max allowable front and rear axles as that would exceed the GVW. 2012 SDV6 - it's missing a couple of cylinders
Post #527389 Thu Jun 01 2017 9:26pm
riverblanche
Hi Robin,
I have had a look at the ones OFF my car Rolling Eyes they are what I understand to be "sparkle silver snow flake" they are the same ones as in Pufftmw pics
the details I can see read as 9J x 19 EH2 OFF53 9 is the width of the rim J is the bead profile, 19 the wheel diameter EH2 to do with the wheels internal design? and OFF53 is the offset
the ones I have for sale are the same ones as Tim has posted istr the details read the same, (there is a long story to do with this on D3 Rolling Eyes ) but the difference between the two sets I have other than the look is the weight of them
these are lighter.
Post #527391 Thu Jun 01 2017 9:35pm
Tim in Scotland
Tomorrow I will look through all my RRS brochures and see if I can find the style/ design codes for the wheels I posted the photos of 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #527393 Thu Jun 01 2017 9:45pm
riverblanche
you can not post any thing else Tim or you will spoil your SonoS inspired post count Laughing
edit... too late ..
Post #527396 Thu Jun 01 2017 9:48pm
Page 1 of 3 123>
