Home > Technical > RRS 2008 2.7 error code P0101-17 MAF SENSOR ?
Schizz
Italy
Hello to all,
I had a few days to replace the 2 egr valves (one was blocked) I thought it was all o.k.
Now ONLY on the highway or when the car runs at constant speed for a few km I turn on the light ENGINE FAILING I stop the car and start immediately without problems and after a while it reappears.
I have inserted a defect reader lm337 wifi and I read error code P0101-17, MAF TEST NOT CANCELED FOR THE OPERATION CYCLE
Yesterday I unplugged it and it was spotlessly clean, I still sprayed the brakes and I put everything back but without getting results, the problem is only visible on long roads, in the city never happens.
What I do ? Switch the sensor? Do I buy VDO brand?
Thank you, sorry for my English ....
My RRS is the year 2008 2.7 diesel.
;O)
Schizz.
Post #525454 Sat May 06 2017 9:52am
Schizz
Italy
Today I saw with LM337 that the value of the MAF vary by accelerating ... so I think the sensor might NOT be defective.
Waiting for your advice before changing it ...
Thank you !
Schizz
Post #525462 Sat May 06 2017 1:20pm
512cello
Belgium 2009 Range Rover Sport TDV6 HSE Lux Santorini Black
Had exactly same problem with my 2.7 from 2009 for about one week after changing EGR valves. Finally used bottle of Forte cleaner and a good, long spirited drive fixed it all. No engine system fault again....
Post #525847 Wed May 10 2017 10:19pm
M3DPO
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Baltic Blue
Change the air filter for an oem filter if it has not been changedcrecently Thumbs Up
Post #525851 Thu May 11 2017 5:51am
Schizz
Italy
Thanks for all !
How of 3 model of "forte cleaner" you are used? Quantity?
Today I change the MAF sensor.
;0)
Schizz
Post #525852 Thu May 11 2017 6:08am
Schizz
Italy
The air filter is new.
Schizz.
Post #525853 Thu May 11 2017 6:09am
512cello
advanced diesel fuel conditioner, small bottle.
Post #525854 Thu May 11 2017 6:19am
Schizz
Italy
Perfect ! Thanks
I keep you up to date
;O)
Schizz
Post #525860 Thu May 11 2017 7:18am
512cello
Update. Got my esf back so hasn't been solved! Only on cold start when driving about 1 kilometer is get ESF with MAF code P0101-17 and car goes into limp mode. Have to stop then to put it in neutral and then it rev's up again.
Already also cleaned MAP sensor but also didn't help.
Going to have to investigate further, keep you updated.
Post #526075 Mon May 15 2017 5:49am
Schizz
Italy
My fault is different ...
Now I have replaced the MAF sensor but I have no courage to go on highway.
My defect occurs at constant speed and after several minutes, the machine goes into "recovery mode" and I have to stop, turn it off and on again, then reappear after a few minutes code error P0101-17
As soon as I can retreat on the highway ... we hope.
In the city the car is perfect no problem.
Schizz
Post #526077 Mon May 15 2017 7:05am
512cello
please give update if new MAF made any difference..
Post #526083 Mon May 15 2017 9:29am
Schizz
Italy
Possible that none of the forums had the same problem?
Post #526084 Mon May 15 2017 9:33am
512cello
After cleaning also my MAF with bardahl egr cleaner didn't get the ESF again since couple of days. Hopefully fixed now.
Post #526313 Thu May 18 2017 11:03am
Schizz
Italy
what's ESF ?
Post #526315 Thu May 18 2017 12:15pm
512cello
engine system fault, car goes in limp mode....
Post #526341 Thu May 18 2017 8:43pm
