Home > Technical > RRS 2008 2.7 error code P0101-17 MAF SENSOR ? |
Schizz Member Since: 03 May 2015 Location: Bologna Posts: 26 |
Today I saw with LM337 that the value of the MAF vary by accelerating ... so I think the sensor might NOT be defective.
Sat May 06 2017 1:20pm |
512cello Member Since: 06 Mar 2017 Location: bree Posts: 6 |
Had exactly same problem with my 2.7 from 2009 for about one week after changing EGR valves. Finally used bottle of Forte cleaner and a good, long spirited drive fixed it all. No engine system fault again.... |
Wed May 10 2017 10:19pm |
M3DPO Member Since: 30 Apr 2013 Location: Notts Posts: 36 |
Change the air filter for an oem filter if it has not been changedcrecently |
Thu May 11 2017 5:51am |
Thanks for all !
Thu May 11 2017 6:08am |
The air filter is new.
Thu May 11 2017 6:09am |
advanced diesel fuel conditioner, small bottle. |
Thu May 11 2017 6:19am |
Perfect ! Thanks
Thu May 11 2017 7:18am |
Update. Got my esf back so hasn't been solved! Only on cold start when driving about 1 kilometer is get ESF with MAF code P0101-17 and car goes into limp mode. Have to stop then to put it in neutral and then it rev's up again.
Mon May 15 2017 5:49am |
My fault is different ...
Mon May 15 2017 7:05am |
please give update if new MAF made any difference.. |
Mon May 15 2017 9:29am |
Possible that none of the forums had the same problem? |
Mon May 15 2017 9:33am |
After cleaning also my MAF with bardahl egr cleaner didn't get the ESF again since couple of days. Hopefully fixed now. |
Thu May 18 2017 11:03am |
what's ESF ? |
Thu May 18 2017 12:15pm |
engine system fault, car goes in limp mode.... |
Thu May 18 2017 8:43pm |
