![]() | Home > Technical > RRS 2008 2.7 error code P0101-17 MAF SENSOR ? |
Schizz Member Since: 03 May 2015 Location: Bologna Posts: 26 ![]() ![]() |
Today I saw with LM337 that the value of the MAF vary by accelerating ... so I think the sensor might NOT be defective.
512cello Member Since: 06 Mar 2017 Location: bree Posts: 6 ![]() ![]() ![]() |
Had exactly same problem with my 2.7 from 2009 for about one week after changing EGR valves. Finally used bottle of Forte cleaner and a good, long spirited drive fixed it all. No engine system fault again.... |
M3DPO Member Since: 30 Apr 2013 Location: Notts Posts: 36 ![]() ![]() ![]() |
Change the air filter for an oem filter if it has not been changedcrecently |
Thanks for all !
The air filter is new.
advanced diesel fuel conditioner, small bottle. |
Perfect ! Thanks
Update. Got my esf back so hasn't been solved! Only on cold start when driving about 1 kilometer is get ESF with MAF code P0101-17 and car goes into limp mode. Have to stop then to put it in neutral and then it rev's up again.
My fault is different ...
please give update if new MAF made any difference.. |
Possible that none of the forums had the same problem? |
After cleaning also my MAF with bardahl egr cleaner didn't get the ESF again since couple of days. Hopefully fixed now. |
what's ESF ? |
engine system fault, car goes in limp mode.... |
