![]() | Home > Maintenance & Modifications > LPG |
Ezituper Member Since: 10 Dec 2016 Location: Herts Posts: 71 ![]() ![]() ![]() |
My 90l tank gives me 260 miles |
Thanks is that mounted in place of the spare wheel asi only managed to get about 35 liters in mine with about a quater of a tank left in it |
Yep
ok so i must have a problem as i only managed about 150 miles and only managed to get 35-36 litres in the tank when the gauge said it only had a quarter in it |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
Perhaps it's because the tank is not fitted horizontally but at an angle and the floating thingy inside the tank doesn't compensate for this. Regards etc.,
I can't see how the rank could be fitted any other way
ok so perhaps i will see how long the gas lasts and go beyond when the red light comes on as the system has had a new sender according to service history |
johnunleashed Member Since: 13 Jul 2014 Location: Lancashire Posts: 59 ![]() ![]() |
don't go off the LPG Gauge they are not good , use your mileage trip . 75lltr I get 248 miles 2007 SUPERCHARGED HST |
well it is full now with 45 liters of gas so i shall see how far i get i did speak to a lpg guy yesterday and he said he could see a problem straight away as the tank is sat at the same angle as the spare would have been which is about 25/30 degrees anyone no if he is telling the truth |
Has anyone got a picture of the rear of there sport with a gas tank mounted so i could possibly see |
PaulFireblade Member Since: 27 May 2017 Location: Milton keynes Posts: 19 ![]() ![]() |
I had an Lpg kit fitted to a previous car:
Thanks but took advice of local installer and ran it till it started flashing and beeping then filled up and got 80 litres in so now i know my gauge is no good as others have said ignore the gauge and go by miles |
Lpg tanks are designed that they will not fill to capacity so a 90 litre tank will not actually hold 90 litres, IIRC something like 80% capacity as Lpg is stored as a gas
So I have a 95 litre tank and I got 80 litres in that to
