Home > Maintenance & Modifications > LPG
geoffsnook
LPG
Hi when i bought my sport supercharged it had a gas conversion with the tank in place of the spare wheel i went for a run out today from cardiff to tenby but did not get there and back on 1 tank Rolling with laughter how many miles roughly will they do on a tank of gas i managed 19.8 on the lie-o-meter but fing 150 miles not very good or could i get a larger tank fitted Thumbs Up
Post #525600 Mon May 08 2017 3:12pm
Ezituper
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
My 90l tank gives me 260 miles
Post #525609 Mon May 08 2017 5:07pm
geoffsnook
Thanks is that mounted in place of the spare wheel asi only managed to get about 35 liters in mine with about a quater of a tank left in it Question
Post #525611 Mon May 08 2017 5:16pm
Ezituper
Yep
Under the back between the exhaust
Post #525617 Mon May 08 2017 6:22pm
geoffsnook
ok so i must have a problem as i only managed about 150 miles and only managed to get 35-36 litres in the tank when the gauge said it only had a quarter in it Thumbs Up
Post #525619 Mon May 08 2017 6:35pm
TheWojtek
Perhaps it's because the tank is not fitted horizontally but at an angle and the floating thingy inside the tank doesn't compensate for this. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #525646 Mon May 08 2017 9:41pm
Ezituper
I can't see how the rank could be fitted any other way
I think there us another issue
Post #525648 Mon May 08 2017 9:54pm
geoffsnook
ok so perhaps i will see how long the gas lasts and go beyond when the red light comes on as the system has had a new sender according to service history Thumbs Up
Post #525664 Tue May 09 2017 6:14am
johnunleashed
2007 Range Rover Sport Supercharged HST Java Black
don't go off the LPG Gauge they are not good , use your mileage trip . 75lltr I get 248 miles 2007 SUPERCHARGED HST
Post #525751 Wed May 10 2017 6:13am
geoffsnook
well it is full now with 45 liters of gas so i shall see how far i get i did speak to a lpg guy yesterday and he said he could see a problem straight away as the tank is sat at the same angle as the spare would have been which is about 25/30 degrees anyone no if he is telling the truth Thumbs Up
Post #525770 Wed May 10 2017 11:48am
geoffsnook
Has anyone got a picture of the rear of there sport with a gas tank mounted so i could possibly see Thumbs Up
Post #525771 Wed May 10 2017 11:52am
PaulFireblade
I had an Lpg kit fitted to a previous car:
Lpg is not as efficient as petrol so you need more of it to do the same job. Mpg dropped about 15% on Lpg over petrol.
Lpg tanks are designed that they will not fill to capacity so a 90 litre tank will not actually hold 90 litres, IIRC something like 80% capacity as Lpg is stored as a gas.
Car still uses petrol to start and Lpg does not cut in until engine up to temp so in winter you need to make sure you keep petrol topped up.
After 40k the big ends went, never had big ends go before on any vehicle so always suspected it might have been the Lpg but could have been a coincidence.
Enjoyed the petrol with diesel economy but it is back to an oil burner for me
Post #527038 Mon May 29 2017 10:36am
geoffsnook
Thanks but took advice of local installer and ran it till it started flashing and beeping then filled up and got 80 litres in so now i know my gauge is no good as others have said ignore the gauge and go by miles Thumbs Up
Post #527051 Mon May 29 2017 1:57pm
Ezituper
They are not designed that way, the 10% you can't fill is Air as you can't have an air vent like a petrol tank
Before you tell some it's stored as a gas maybe google what lpg stands for lol
Post #527090 Mon May 29 2017 7:55pm
geoffsnook
So I have a 95 litre tank and I got 80 litres in that to
Me sounds about right so why would I need to google lpg I know what it stands for Rolling Eyes
Post #527091 Mon May 29 2017 8:02pm
