![]() | Home > General > DVD Map - Read Error |
Graz Member Since: 22 Apr 2013 Location: Essex Posts: 104 ![]() ![]() |
I've started to this showing on the screen recently. Do I need to upgrade the satnav disc? |
I'll give that a try, cheers. Also just ordered a 2015 updated disc so at least I've got the latest maps. |
Latest maps should now be the 2017 version, not sure if the same applies to disc version? But would have thought so, have a check on the "HERE" site, official LR map site.
Land Rover only do update discs up till 2012 after that there are no newer discs for the older style dvd drive if you want newer it will be a disc from ebay but not official |
Thanks for that updated info Geoff, didn't realise officially no longer available. As stated though available through EBay |
All fixed. I ran a cleaner disc through it but also bought a new upgraded 2014/15 map DVD and all is well. The cleaner may have fixed it on its own but for an extra �30 at least I have more up to date maps. |
Glad you are all sorted. |
