Home > General > DVD Map - Read Error
Graz
I've started to this showing on the screen recently. Do I need to upgrade the satnav disc?
Post #524553 Wed Apr 26 2017 6:16pm
geoffsnook
clean it first i had it on mine your dvd drive may be on its way out bt give it a try with the cleaning disc first Thumbs Up
Post #524556 Wed Apr 26 2017 6:36pm
Graz
I'll give that a try, cheers. Also just ordered a 2015 updated disc so at least I've got the latest maps.
Post #524560 Wed Apr 26 2017 7:19pm
Johnski
Latest maps should now be the 2017 version, not sure if the same applies to disc version? But would have thought so, have a check on the "HERE" site, official LR map site.
You most probably know, but discs can get dirty, greasy etc, just remember to clean them from the centre straight outwards towards the edge, never in circles as can permanently damage the disc, use a soft lint cloth with cleaning solution, blow across the disc first to remove loose dust/particles, to prevent scratching or damaging disc. Whistle
The laser if on way out or gone can be replaced relatively easily, you see replacements on EBay at times too. John
Post #524598 Thu Apr 27 2017 12:46am
geoffsnook
Land Rover only do update discs up till 2012 after that there are no newer discs for the older style dvd drive if you want newer it will be a disc from ebay but not official Thumbs Up
Post #524604 Thu Apr 27 2017 7:23am
Johnski
Thanks for that updated info Geoff, didn't realise officially no longer available. As stated though available through EBay Whistle but not for HD or other systems since. Crying or Very sad John
Post #524674 Thu Apr 27 2017 6:06pm
geoffsnook
Post #524695 Thu Apr 27 2017 8:54pm
Graz
All fixed. I ran a cleaner disc through it but also bought a new upgraded 2014/15 map DVD and all is well. The cleaner may have fixed it on its own but for an extra �30 at least I have more up to date maps.
Post #524848 Sat Apr 29 2017 5:30pm
Johnski
Glad you are all sorted. Very Happy John
Post #524859 Sat Apr 29 2017 6:32pm
