Home > Maintenance & Modifications > Bottle Jack Adaptor ?
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
Has anyone found an adaptor for a bottle jack that allows it to locate into the holes on the chassis, that are used with the normal scissor jack ? (I've tried rummaging around Ebay, but either I'm using the wrong words for the search, or it doesn't exist !)
Thanks. Thumbs Up
Post #523842 Mon Apr 17 2017 8:31am
Disco Bottle Jack
Post #523843 Mon Apr 17 2017 9:05am
gogsy1956
I've an adapter my trolley jack that does this,, but I made it myself, that may.be the only way you will get one 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #523885 Mon Apr 17 2017 8:48pm
Socast
I use (dependant on ground type) two lumps of wood, one for the jack to sit on and the other between the chassis and the top of the jack.
Post #523909 Tue Apr 18 2017 8:32am
Paddi
Check the Disco3 site (as already suggested) but search for 'sprinter jack'. You'll find threads on how ideal the bottlejack from a Merc sprinter is for the Disco/RRS and apparently if you unscrew the top pad it exposes a nice pointy bit that fits into the chassis hole. Adding a massive penny washer helps to spread the load making a neat engineering solution.
Never bothered myself - if caught out on the road with a flat I'm calling the AA so they can actually do something for their over-inflated annual fee. 2008 MY Java Black TDV8 HSE
Post #523944 Tue Apr 18 2017 1:21pm
Scrumpy
I got one of these on eBay fo �9 and it does the job with a bottle jack although I would prefer the bottom to be recessed a bit.
http://www.ebay.co.uk/itm/LANDROVER-RANGE-...SwUuFWyNQJ
Alternatively just search for "Range rover Jacking Pad" 2016 RRS SVR Estoril Blue
Post #523955 Tue Apr 18 2017 3:42pm
