Home > Maintenance & Modifications > Bottle Jack Adaptor ? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4966 |
Mon Apr 17 2017 9:05am |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 946 |
I've an adapter my trolley jack that does this,, but I made it myself, that may.be the only way you will get one 2010 RRS, TDV8
Mon Apr 17 2017 8:48pm |
I use (dependant on ground type) two lumps of wood, one for the jack to sit on and the other between the chassis and the top of the jack. |
Tue Apr 18 2017 8:32am |
Check the Disco3 site (as already suggested) but search for 'sprinter jack'. You'll find threads on how ideal the bottlejack from a Merc sprinter is for the Disco/RRS and apparently if you unscrew the top pad it exposes a nice pointy bit that fits into the chassis hole. Adding a massive penny washer helps to spread the load making a neat engineering solution.
Tue Apr 18 2017 1:21pm |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 |
I got one of these on eBay fo £9 and it does the job with a bottle jack although I would prefer the bottom to be recessed a bit.
Tue Apr 18 2017 3:42pm |
