![]() | Home > General > Suspension - leaning to the left! |
Get fault codes read first to give you an idea. Use a good local independent specialist near you. Find one by using the search facility on here and input your town or try your county |
Give Andy a call at Landers Garage:
TomTerrain Member Since: 07 Sep 2015 Location: Wirral Posts: 93 ![]() ![]() ![]() |
FYI, I have exactly the same issue. The lean is very prominent in off-road height! I have IID, and no codes showing! 2006 Java Black HST Supercharged |
stornoway10 Member Since: 03 Feb 2013 Location: Southport Posts: 60 ![]() ![]() ![]() |
Mine did that
Ride height already recalibrated. My air bags are original and looking pretty worn, so might change them out 2006 Java Black HST Supercharged |
Ianm Member Since: 23 Dec 2015 Location: St. Albans Posts: 25 ![]() ![]() ![]() |
New compresser fitted @ independent garage & alls well, £1000 all but a beer |
£1000 to supply and fit a compressor? Sounds a bit steep. 2012 SDV6 - it's missing a couple of cylinders
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
Was the thing thinking the same, my local Indy (venture 4x4) charged £685 to change a Hitchi to an AMK |
grey17 Member Since: 18 Jul 2016 Location: Devon Posts: 63 ![]() ![]() ![]() |
Hi mate.
