Home > General > Suspension - leaning to the left! |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Get fault codes read first to give you an idea. Use a good local independent specialist near you. Find one by using the search facility on here and input your town or try your county
Wed Mar 29 2017 7:49pm |
Give Andy a call at Landers Garage:
Thu Mar 30 2017 11:16am |
TomTerrain Member Since: 07 Sep 2015 Location: Wirral Posts: 93 |
FYI, I have exactly the same issue. The lean is very prominent in off-road height! I have IID, and no codes showing! 2006 Java Black HST Supercharged |
Wed Apr 05 2017 11:59am |
stornoway10 Member Since: 03 Feb 2013 Location: Southport Posts: 60 |
Mine did that
Fri Apr 07 2017 7:50pm |
Ride height already recalibrated. My air bags are original and looking pretty worn, so might change them out 2006 Java Black HST Supercharged |
Fri Apr 07 2017 8:18pm |
Ianm Member Since: 23 Dec 2015 Location: St. Albans Posts: 25 |
New compresser fitted @ independent garage & alls well, £1000 all but a beer |
Sat Apr 08 2017 6:51am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
£1000 to supply and fit a compressor? Sounds a bit steep. 2012 SDV6 - it's missing a couple of cylinders
Sat Apr 08 2017 12:55pm |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
Was the thing thinking the same, my local Indy (venture 4x4) charged £685 to change a Hitchi to an AMK |
Sat Apr 08 2017 2:23pm |
grey17 Member Since: 18 Jul 2016 Location: London Posts: 62 |
Hi mate.
Mon Apr 10 2017 3:14pm |
