Home > Technical > Cam belt
m3nutter
England 2007 Range Rover Sport TDV6 HSE Zermatt Silver
Cam belt
When I bought my 2.7 last summer, at just under 100k on the clock the chap told me that at 85k it had a 105k service and both belts done. I thought I'd check do today I phoned the garage that did the service , and they said they had done 105k service but the chap had said not to do belts as they were done a year before. I've phoned the garage who did the previous service and they didn't di it either!
Bearing in mind the owner at the time may not have been fibbing as an Indy may have done it , but I doubt it Sad
Looks like I will be getting my spanners out again Shocked
Post #522038 Mon Mar 27 2017 1:50pm
geoffsnook
Better safe than sorry i say get them spanners out Thumbs Up
Post #522044 Mon Mar 27 2017 2:21pm
m3nutter
I reckon you're right.
What was the oil pump bracket issue ?
Post #522074 Mon Mar 27 2017 4:33pm
geoffsnook
it was not the bracket it was a bad batch of oil pumps where the casting was floored and failed so while you are doing the belt its worth doing the pump at the same time Thumbs Up
Post #522080 Mon Mar 27 2017 5:33pm
Yeah get your front belt and oil pump replaced.
Recover, and then do the rear one if your mad enough Confused
Post #522089 Mon Mar 27 2017 6:23pm
m3nutter
Thumbs Up yeah that was my plan Andy , I thought at least getting the front done is peace of mind Mr. Green
Post #522098 Mon Mar 27 2017 7:45pm
m3nutter
How much should I be paying for a kit with idlers ?
Post #522099 Mon Mar 27 2017 7:46pm
Look on eBay. Used to do a kit with aux belt too
And free locking kit if you ordered by phone. (well used to)
http://www.ebay.co.uk/itm/RANGE-ROVER-SPOR...SwKIpWC~as
�170
Post #522105 Mon Mar 27 2017 8:40pm
m3nutter
Ok mate thanks,
I'm thinking about oil pump to. Just been trying to catch up on all the posts to see if mine could have an issue and I suspect it can. It's SALLSAA137A...
Do you know if the crank pulley is on a tapered key ? I suppose it very tight and needs the flywheel locking to undo ?
N
Post #522108 Mon Mar 27 2017 9:05pm
Dont know. The Citroen pumps are better priced.
Post #522112 Mon Mar 27 2017 9:45pm
flack
The crankshaft pulley is not on a key way and it needs to locked via the flywheel locking tool., Advanced Factors have all you need including the oil pump.
http://www.advancedfactors.co.uk/
Flack Thumbs Up
Post #522113 Mon Mar 27 2017 9:52pm
m3nutter
Ok thanks , so it's just a taper , I'm just thinking once it's off any timing reference is lost so you have to use flywheel ?
Nick
Post #522115 Mon Mar 27 2017 10:04pm
