Home > Technical > Cam belt |
Better safe than sorry i say get them spanners out |
Mon Mar 27 2017 1:21pm |
m3nutter Member Since: 08 Jul 2016 Location: Fairoak, Eastleigh Posts: 145 |
I reckon you're right.
Mon Mar 27 2017 3:33pm |
it was not the bracket it was a bad batch of oil pumps where the casting was floored and failed so while you are doing the belt its worth doing the pump at the same time |
Mon Mar 27 2017 4:33pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4950 |
Yeah get your front belt and oil pump replaced.
Mon Mar 27 2017 5:23pm |
yeah that was my plan Andy , I thought at least getting the front done is peace of mind |
Mon Mar 27 2017 6:45pm |
How much should I be paying for a kit with idlers ? |
Mon Mar 27 2017 6:46pm |
Look on eBay. Used to do a kit with aux belt too
Mon Mar 27 2017 7:40pm |
Ok mate thanks,
Mon Mar 27 2017 8:05pm |
Dont know. The Citroen pumps are better priced. |
Mon Mar 27 2017 8:45pm |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
The crankshaft pulley is not on a key way and it needs to locked via the flywheel locking tool., Advanced Factors have all you need including the oil pump.
Mon Mar 27 2017 8:52pm |
Ok thanks , so it's just a taper , I'm just thinking once it's off any timing reference is lost so you have to use flywheel ?
Mon Mar 27 2017 9:04pm |
