Home > Off Topic - Other Cars > Meet the new Range Rover VELAR
Page 17 of 41 <123 ... 161718 ... 394041>
Tim in Scotland wrote:
One of the biggest problems with diesels is the way that they are used. They are not for small cars that do short journeys. Also people buy them because of headline mpg, yet many small turbo charged petrols are actually as good or even better for short trips. Short trips with lots of gear changing are not what diesels are about, they are much less polluting and more efficeint drive at steady speed over longer distances, ie once fully warmed through, yet many are used for commuter driving over distances less than 15 miles.
Indeed. My TDV8 does several mpg more at a steadyish 70mph (cough) than it does in town. Of course, not having to constantly re-accelerate a 2.5 tonne lump does wonder for fuel economy. 2012 SDV6 - it's missing a couple of cylinders
Post #520398 Wed Mar 08 2017 9:19pm
insiorc wrote:
I understand Diesel being dirtier on a per litre burnt basis, but what about over a given mileage? Surely the increased fuel efficiency has to have some impact on the overall dirt? Typical Range Rover Sport traffic jam idling excepted of course...
Dennis
The problem is that to constantly improve mpg and reduce CO2, the engines are driven at higher compression ratios and, more significantly, higher temperatures. This plays in to the hands of the dreaded NOx. NOx is a nasty little group that has real negative health issues.
One of the great ironies of recent times is that biodiesel apparently creates more NOx than oil-sourced diesel. 2012 SDV6 - it's missing a couple of cylinders
Post #520400 Wed Mar 08 2017 9:28pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Just googled NOx - they'd better start banning it in farming too then as the tractors driving past my garden flinging that Censored around can't be too healthy either then:
Agricultural fertilization and the use of nitrogen fixing plants also contribute to atmospheric NOx, by promoting nitrogen fixation by microorganisms
Or we better start cutting out all the lightning strikes around the world too since they contribute 8.6 million tonnes of NOx
I'd guess it's really just another way to raise money Big Cry 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #520406 Wed Mar 08 2017 9:52pm
NOx is an issue in cities because in the presence of sunlight it reacts with oxygen to make ozone. Ozone is "a bad thing" at ground level - it's fabulous in the upper atmosphere but a nasty irritant of the eyes and lungs down here. A bit of NOx out in the fields is probably less of a problem as it can be rapidly diluted but in the relatively closed environment of a city street it's less desirable, 2012 SDV6 - it's missing a couple of cylinders
Post #520413 Wed Mar 08 2017 10:05pm
donny dog
Of course, Laughing Gas is also one of the oxides of nitrogen (N2O) and people breathe that for fun.
Post #520414 Wed Mar 08 2017 10:10pm
Indeed so, but you wouldn't want to breathe it constantly... Whistle 2012 SDV6 - it's missing a couple of cylinders
Post #520416 Wed Mar 08 2017 11:23pm
Tim in Scotland
My daily work transport has a single 29,000kW Diesel engine thumping along at 104 rpm (at the moment it is putting out 2,900kw at 47 rpm), four years ago we had to fit NOX reduction equipment and now NOX emissions meet international requirements however despite now using very low and ultra low sulphur fuels we produce huge amounts more particulate that disolves into sulphuric acid when it rains on our deck............. even running in hybrid mode, as some ferries do, they still have to generate the electricity somehow to charge the batteries so more generators are fitted................. more diesel is burned! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #520417 Thu Mar 09 2017 6:17am
Are you sure the particulates form sulphuric acid Tim? If you're running ULS fuel where does the sulphur come from? Or is it just down to the amount of fuel you burn? 2012 SDV6 - it's missing a couple of cylinders
Post #520429 Thu Mar 09 2017 9:50am
Tim in Scotland
Once the carbon smuts dissolve in rain and stay on deck, the sun evaporates the liquid to a yellow colour fluid then to yellow crystal, I have always been told that is sulphuric acid. Might be something else with the low grade fuels we burn. Once out of port or the SECA areas then we burn the cheapest high sulphur fuel that the engine can handle. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #520430 Thu Mar 09 2017 9:53am
RRSman
This makes interesting reading!
http://europe.autonews.com/article/2017030...ofile=1164
Post #520542 Fri Mar 10 2017 1:32pm
donny dog
Tends to ignore the fact that there's a facelifted RRS in the pipeline in that timescale.
Post #520544 Fri Mar 10 2017 1:37pm
RRSman
Correct but from what I have heard the FFRR will be updated before the RRS - expect to see the new FFRR before the end of the year and the MY18 RRS in March next year.
Post #520546 Fri Mar 10 2017 1:45pm
donny dog
I think some people might also dispute that the Velar can do everything a RRS can do. I can't see why there wouldn't be room for both variants going forward. Also, if they make the RRS longer, as he suggests, that will narrow the gap on the FFRR which will also have to extend - at this rate the top models will be 100 feet long by 2030! Shocked
Post #520547 Fri Mar 10 2017 1:56pm
SVR575
Lol When does it stop? wait for the new sport wait for the new FF. SVR 2018 in Santorini Black.
Post #520555 Fri Mar 10 2017 3:52pm
RRSman
I'm not waiting lol buy RRS, sell, Buy Velar, Sell buy new sport 2018 Very Happy
If you play the timing game correctly should not lose much on any of these choices!
Another intersting article! http://www.autoexpress.co.uk/best-cars/873...value-best
Post #520556 Fri Mar 10 2017 3:56pm
