Home > General > Serious savings on a TDV8 injector repair
Sharpy1980
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
The injectors themselves are identical internally but it's to do with the direction the solenoid points in relation to the fuel pipes, in the photo you can see that 1&2 for example have the solenoid plugs pointing towards each other yet the fuel pipes come out the same
 Clickadeeclick
Post #519850 Sat Mar 04 2017 5:05pm
d-9
LR specifiy you must replace the injector fitting kit whenever injectors are removed. The kit includes the pipe and the bits that hold the injectors down which apparently distort as you torque them down. If you reuse them the pipes are prone to leak and the combustion charge can leak past the injector, filling the injector wells with soot/tar.
Post #519882 Sat Mar 04 2017 9:41pm
Sharpy1980
The new injectors came with everything bar the pipe
Cheers Clickadeeclick
Post #520392 Wed Mar 08 2017 8:13pm
d-9
Thats a bargain then!
Post #520402 Wed Mar 08 2017 9:33pm
Kev1960
England 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Hi Paul, I'm new here and looking for good guy to replace an injector on my TdiV8.
I'm in North Herts and would like the number of the guy you used.
Post #532950 Tue Aug 15 2017 11:14pm
