Home > General > Serious savings on a TDV8 injector repair |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 311 |
LR specifiy you must replace the injector fitting kit whenever injectors are removed. The kit includes the pipe and the bits that hold the injectors down which apparently distort as you torque them down. If you reuse them the pipes are prone to leak and the combustion charge can leak past the injector, filling the injector wells with soot/tar. |
Sat Mar 04 2017 9:41pm |
Sharpy1980 Member Since: 24 Sep 2016 Location: Kent Posts: 98 |
The new injectors came with everything bar the pipe
Wed Mar 08 2017 8:13pm |
Thats a bargain then! |
Wed Mar 08 2017 9:33pm |
Kev1960 Member Since: 15 Aug 2017 Location: Hertfordshire Posts: 1 |
Hi Paul, I'm new here and looking for good guy to replace an injector on my TdiV8.
Tue Aug 15 2017 11:14pm |
