Home > General > New torque converter problems
Michaelgmcb
Just got a Range Rover sport, 2006, 2.7, automatic. I had experienced a shuddering and got the torque converter replaced, car ran fine for 2 days, and now the shuddler is slowly creeping back along with a groaning noise when the acceleratior is sometimes pressed, it has just happened a few times, any ideas what it could be? There has been no fault lights or anything showing up, could it be the reconditioned torque converter I got put in?
Many thanks
Michael
Post #519818 Sat Mar 04 2017 12:58pm
Disco_Mikey
Have only ever used new OEM units, and never had an issue afterwards...
It would suggest either an issue with the recon TC, or a further mechanical issue within the box
Post #519832 Sat Mar 04 2017 2:54pm
Michaelgmcb
got the gearbox oil and filter replaced and again the problem went away for a day then game back way worse. it seemed to be ok for a day when the torque converter was replaced, came back, went and got the gearbox oil and filter replaced then it was ok and now it is back again. any suggestions?
Post #521434 Mon Mar 20 2017 5:42pm
DrRob
Take it back and tell them to fix it properly! Visitor from fullfatrr.com
Post #521438 Mon Mar 20 2017 6:05pm
Michaelgmcb
Do you think it's one of the 2 things that were replaced that are at fault?? Cost me nearly £1500 and still in the same position
Post #521439 Mon Mar 20 2017 6:07pm
Socast
Bristol Auto's are specialists with an amazing reputation. Might be worth getting their opinion.
Post #521441 Mon Mar 20 2017 6:11pm
Michaelgmcb
What are they called or would you have a number so I could contact them?
Post #521442 Mon Mar 20 2017 6:12pm
Socast
Sorry, Bristol Transmissions. Heres a link: http://www.bristoltransmissions.co.uk/shop/
Post #521443 Mon Mar 20 2017 6:15pm
