Home > Maintenance & Modifications > Engine System Fault Back |
Jock 77 Member Since: 13 Apr 2012 Location: Falkirk Posts: 187 |
Hi Lads
Thu Feb 16 2017 3:23pm |
Hi Andy
Thu Feb 16 2017 8:23pm |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 |
When I first got mine almost 2 years ago now. I had engine system fault come up constantly, it was usually at just over 70mph, and this was happening for several months, very annoying! Then I started using vpower diesel and had a few months of very low fuel economy with spirited driving and im guessing i must have got lucky and freed everything off. The car used to belong to my mum for the previous 3 years to me owning it, and it was used as a get around car for town and to shop in so it never really saw over 50 mph. Fingers crossed, touch wood, grasping a four leaf clover, now it's doing daily 50mile commutes up and down duel carriage way, at speed it's never thrown up the message again. And it's performing much better at higher speeds now.
Thu Feb 16 2017 9:58pm |
Do you not need to reprogram the ECU after blanking the EGR valves, or is that only the tdv8 ? |
Fri Feb 17 2017 7:54am |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Socast
Fri Feb 17 2017 8:22am |
Hi Lads
Fri Feb 17 2017 11:51am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4966 |
Maybe the experts can help here, but what I don't understand is that if the motor has failed in the EGR, and the ecu can see this with its feedback, why blanking the EGR's will actually make the fault go away.
Fri Feb 17 2017 12:15pm |
Hi Lads
Fri Feb 24 2017 1:55pm |
what codes are you getting now?
Fri Feb 24 2017 3:03pm |
Hi Andy
Fri Feb 24 2017 8:25pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4403 |
Most likely the actuator is not free enough. I have had to work them for (literally) hours on the worst ones...
Fri Feb 24 2017 9:06pm |
Thanks Mikey
Fri Feb 24 2017 10:09pm |
Is the car quick to drive.
Fri Feb 24 2017 10:30pm |
Hi Andy
Fri Feb 24 2017 10:43pm |
