Home > Maintenance & Modifications > Engine System Fault Back
Jock 77
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
Re.Engine System Fault
Hi Lads
Just an update, at present running a Turbo cleaner through the fuel ,the car appears to be running better so I suppose it can't have done it any harm. I did Have the Fault up a couple of times while carrying this out but this time it was a Special Programs off and into limp mode.
Hope to go back in tomorrow and have another look at the Turbo actuator.
Still looking to also change the Turbo hoses and have seen Bearmach set BA2341 : Silicone Turbo Hose Kit Blue with the protecting socks and new jubilee clips from Totalparts at £98+vat ,take it these would be adequate.
Only other thing I have noticed which has been there for quite sometime is quite a drone from inside the car down around the Turbo area when accelerating from lower speeds, any ideas if this could be a leak in one of the hoses down at the Turbo. Confused
I couldn't see any leaks in these the last time I was in at the actuator.
Cheers Jock Thumbs Up
Post #520671 Sun Mar 12 2017 11:50am
Jock 77
Re Engine System Fault.
Hi Lads another update
Checked the Turbo Actuator again and sprayed it up ,but all felt fine on original check. I have run the Turbo cleaner through the car and was on holiday for a week and put about 750 miles on it using also V power Diesel.
Again during these miles I had the faults up around 8-10 times but they differed between Engine System Fault and Special Programs Off both resulted in Limp Mode and cleared again when the car was switched off and back on. Not sure if it was coincidence or not but when I thought I was coming to an area when the fault would occur I was selecting Manual and dropping a gear to try and help and the fault never came up. Confused
The fault has came up again a couple of times in the last week ,A friend in a nearby garage has offered to do a smoke test on my Air pipework and hoses/Intercooler in the next week or say. So will see how that goes.
Cheers Jock. Big Cry
Post #522568 Sat Apr 01 2017 7:39pm
Joe-D
United Kingdom 2008 Range Rover Sport TDV6 SE Java Black
Re: Re Engine System Fault
Jock 77 wrote:
Hi Andy
Pushed the car on today after tightening the hoses and still feel it is performing well. When the fault comes up the car appears to keep the power for a very short time and then when you slow down it appears to go into the limp mode with very little power and won't rev.
If I stop and put into neutral it will rev up as normal ,so that baffles me a bit too.
Hi Jack
I am having very similar issues to the ones described here, however I have found that although there is no fault on the MAF the actual live data is recording 0.00 which in my mind means that this is being bypassed in someway. I am at the garage next week so hopefully get to the bottom of it - Please let me know if you find the same non activity from the MAF?
Post #523603 Fri Apr 14 2017 8:12am
Jock 77
Hi Joe
Thanks for the reply ,I still haven't got to the bottom of my fault. I am hoping to have a smoke test carried out in the next few weeks to check all hoses and Intercooler. If that seem okay then I am going to pop it up and leave with Mikey to try and track down.
Not sure how to get the readings from the MAF. Not sure if you could advise me on that. And again if you do find anything else with yours if you could let me know that would be great.
Post #523621 Fri Apr 14 2017 12:23pm
Joe-D
Hi Jock
if you can attach a decent OBD reader you should ber able to see all the live data and the MAF should be reading in between
2-9 dependent on acceleration however if like mine it is reporting 00.00 Ib/min which means it is not even at the party.
I have it booked into whites Landlover specialist in Dalry Edinburgh on Monday so hopefully get to the bottom of it then. Hope you get to the bottom of your issue also.
I am just over in Livingston.
Joe
Post #523630 Fri Apr 14 2017 4:36pm
Disco_Mikey
The MAF reports values in g/s Confused
If it's reporting 0 reading, is there any reason why you suspect it's not a faulty MAF?
Post #523631 Fri Apr 14 2017 4:58pm
Jock 77
Hi Joe
Thanks again for keeping me up to date, I don't have a OBD reader that would read this at the moment. If you don't mind keeping me up to date with how you get on that would be great.
Mike as I had mentioned I hope to get Smoke test done in next couple of weeks ,Failing that will be in touch to see if you can book me in to track down fault bud. Thumbs Up
Cheers Jock.
Post #523668 Sat Apr 15 2017 7:23am
Joe-D
Hi Mike
This is with a brand new MAF, in total I have used three all with the same issues being maintained.
The MAF seems to be either not being read by the ECU or there is an electrical gremlin somewhere.
Post #523679 Sat Apr 15 2017 9:29am
Disco_Mikey
Then you have either a wiring issue to the MAF (most likely) or an ECU fault (highly unlikely)
Post #523739 Sat Apr 15 2017 7:07pm
