![]() | Home > Technical > Mud and Ruts setting warning with towing electrics fitted |
DrRob
Ta. Did it say "Low range not selected" or something similar? Visitor from fullfatrr.com
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
Dr Rob, I've just checked on my 2012 and the only message is advise select low range, I have 7 pin tow electrics fitted and coded by Bodsy. Is the coding incorrect or a fault with the connections? |
I've asked Guava to check it when it goes in for its service soon.... Visitor from fullfatrr.com
If im back from offshore before your service you can plug into mine and try it Rob. |
Engage Low Range
